<p class="MsoNormal" style="textindent: 18pt margin: 0cm 0cm 0pt 18pt msolist: l0 level1 lfo1 msohyphenate: none tabstops: list 18.0pt"><strong style="msobidifontweight: normal"><span style="fontfamily: 宋体 fontsize: 16pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">鳞片型环氧富锌
涂料<span><strong><span style="fontsize: 16pt" lang="ENUS"><span><p>
<p class="MsoNormal" style="margin: 0cm 0cm 0pt msohyphenate: none"><span style="fontsize: small"><strong style="msobidifontweight: normal"><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">主要性能:<span><strong><strong style="msobidifontweight: normal"><span style="msobidifontsize: 10.5pt" lang="ENUS"><span><strong><span><p>
<p class="MsoNormal" style="textindent: 21.75pt margin: 0cm 0cm 0pt msohyphenate: none"><span style="fontsize: small"><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">由鳞片状锌粉、环氧树脂和改性固化剂组成的双组份富锌涂料。<span><span style="msobidifontsize: 10.5pt" lang="ENUS"><span><span><p>
<p class="MsoNormal" style="margin: 0cm 0cm 0pt 37.5pt msohyphenate: none msoparamarginleft: 3.57gd"><span style="fontsize: small"><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">抗蚀性能优异、采用鳞片状锌粉作为填料,在
涂层中形成了瓦片搭接状的平行结构,使涂层具有高抗蚀性、高屏蔽性,电化学保护性能优良,其长寿命耐盐雾性能达到<span><span style="msobidifontsize: 10.5pt" lang="ENUS">50000h<span><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">优于现有市场上普通环氧富新涂料;<span><span style="msobidifontsize: 10.5pt" lang="ENUS"><span><span><p>
<p class="MsoNormal" style="textindent: 37.5pt margin: 0cm 0cm 0pt msohyphenate: none msocharindentcount: 3.57"><span style="fontsize: small"><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">屏蔽性好,抗渗透性能强;<span><span style="msobidifontsize: 10.5pt" lang="ENUS"><span><span><p>
<p class="MsoNormal" style="textindent: 6pt margin: 0cm 0cm 0pt 31.5pt msohyphenate: none msoparamarginleft: 3.0gd msocharindentcount: .57"><span style="fontsize: small"><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">涂层附着力强,柔韧性强,涂料采用新型固化环氧树脂,防锈性能好,附着力佳,若限于施工条件,可以采用手工除锈的方式,但除锈等级必须达到<span><span style="msobidifontsize: 10.5pt" lang="ENUS">St3<span><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">级,从而降低了施工难度;<span><span style="msobidifontsize: 10.5pt" lang="ENUS"><span><span><p>
<p class="MsoNormal" style="textindent: 0.75pt margin: 0cm 0cm 0pt 31.5pt msohyphenate: none msoparamarginleft: 3.0gd msocharindentcount: .07"><span style="fontsize: small"><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">施工性能好、涂料采用鳞片状锌粉作填料,料浆密度小,悬浮性好,不易产生球状锌粉填料引起的堵抢等施工问题。<span><span style="msobidifontsize: 10.5pt" lang="ENUS"><span><span><p>
<p class="MsoNormal" style="margin: 0cm 0cm 0pt msohyphenate: none"><span style="fontsize: small"><strong style="msobidifontweight: normal"><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">主要用途<span><strong><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">:<span><span style="msobidifontsize: 10.5pt" lang="ENUS"><span><span><p>
<p class="MsoNormal" style="margin: 0cm 0cm 0pt msohyphenate: none"><span style="fontsize: small"><span style="msobidifontsize: 10.5pt" lang="ENUS"><span style="msospacerun: yes">     <span><span><span style="fontfamily: 宋体 msobidifontsize: 10.5pt msoasciifontfamily: "Times New Roman" msohansifontfamily: "Times New Roman"">适用于桥梁、石油储罐、钢网架等各类钢结构的防护用底漆以及车间底漆。<span><span><span style="msobidifontsize: 10.5pt" lang="ENUS"><span><p>
